Pete & KW related Help...
Threads
- W900L blower problem (7 Replies)
- Accelerator lag (2 Replies)
- Pete PTO wiring (2 Replies)
- suspension (1 Reply)
- Paccar fuel filter doesn't stay full (23 Replies)
- Driving an air ride without air (5 Replies)
- Driveshaft alignment (8 Replies)
- New battery cables... (3 Replies)
- Water in the cab (6 Replies)
- Wheel sensor (13 Replies)
- Pete 579 (8 Replies)
- Got a ? For you Pete boys (4 Replies)
- Adding A/C & Heat to 36" sleeper (8 Replies)
- Low beam fault (4 Replies)
- Poly bushings (10 Replies)
- Worn out cab bushings (8 Replies)
- Hmmm...air leak. (16 Replies)
- Pete 386 exhaust (2 Replies)
- Ball joints... (6 Replies)
- 2011 peterbilt 386 replacing turbo-actuator (16 Replies)
- EGT Gauge in a T800 (27 Replies)
- DEF Cleaning (2 Replies)
- Leaf springs... (9 Replies)
- tag axle ABS problem (6 Replies)
- Kenworth T-800 dash switches (3 Replies)
