01-01-2017,
My torque wrench does torque plus and it reads out torque once torque plus is done and it works out to be about 100ftlbs.
(01-01-2017 )gearhead Wrote: [ -> ]My torque wrench does torque plus and it reads out torque once torque plus is done and it works out to be about 100ftlbs.
(01-01-2017 )Hammerhead Wrote: [ -> ](01-01-2017 )gearhead Wrote: [ -> ]My torque wrench does torque plus and it reads out torque once torque plus is done and it works out to be about 100ftlbs.
What kind of torque wrench have you got that records the final number like that for you Gearhead?
Mine are atypical Snap-On and Mac click type.
(12-30-2016 )Pigpen 2868 Wrote: [ -> ]That sounds like a response from one of the counters in Dedham Mass.
(01-01-2017 )Rawze Wrote: [ -> ](12-31-2016 )Hammerhead Wrote: [ -> ]Thanks for the update, I will update my procedure printout!
I couldn't agree more on a set torque spec. There are items where torque plus angle is necessary, but Cummins seems to really overuse it IMHO.
I could feel that 70 was a fair amount less than the procedure, but I've checked mine a couple of times and they haven't been loose, so I've left well enough alone. I'm planning on replacing a couple injectors shortly, so I'll put this new info to use!
Just remember that you want to wick out any oil from the holes before installing the bolts. I have seen that mistake before, and the results are sometimes not pretty.
(01-01-2017 )earnies2 Wrote: [ -> ]UPDATE....I got it all back together to include a new Rocker box Gasket and started it up and it ran like crap it was skipping and smoking....i was panicked :waaaht: so i started to back-check everything i did to make sure i didn't miss anything and decided to unplug one injector at a time to do a back yard cyl balance test as soon as i grabbed the harness it started to run better than like crap again so i removed the new injection harness and installed the old one and it runs great....i cant believe a new harness was defective....i am happy that i did the injectors myself and it will give me the confidence to do the one on my ISX in the future....
