03-06-2016,
I have Insite on my laptop and the $300 adaptor, but my prefered method for reading codes is a BAFX bluetooth code reader attached to a 9 pin adaptor ($38 total). A cheap way to receive and transmit codes in English:
For $38 you could put a BAFX code reader and adaptor in each truck. This reader works with an android phone via blue tooth. Free Cummins App. called Fault Advisor. The snap shot gives all the codes for Eng., Trans., body and brakes. The snap shot can then be shared via email or text.
This is much easier to use than my lap top and insite. Amazon has both.
Mo-Co-So 1m/39" Compact 9 Pin Male Deutsch J1939 to 16 Pin J1962 OBD-II Female for GPS Trackers and Scan Tools
http://www.amazon.com/Mo-Co-So-Compact-D...JKVFRQGMC0
BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices (this is the only one that works!)
http://www.amazon.com/BAFX-Products-34t5...BX3J3HTWCE
You will also need to go here and signup for Cummins Quickserve on your computer. https://quickserve.cummins.com/info/index.html
It's a FREE SHOP MANUAL ONLINE! Once your logged in go to SERVICE - Fault Code Search - SPN/FMI To Fault Codes.
Enter the codes from the reader here.
I have used this on a CM876 and a CM2250. Works great.
Tags:
read codes, isx fault codes, isx code reader, insite alternative, android, read fault codes
