03-05-2017,
Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks.
(03-05-2017 )Dd614 Wrote: [ -> ]Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks.
(03-05-2017 )Squish099 Wrote: [ -> ](03-05-2017 )Dd614 Wrote: [ -> ]Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks.
What does quickserve say the codes are? If you don't have a quickserve account it's free from cummins, if you register your esn to your account..
(03-06-2017 )Dd614 Wrote: [ -> ](03-05-2017 )Squish099 Wrote: [ -> ](03-05-2017 )Dd614 Wrote: [ -> ]Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks.
Engine Fuel Shutoff Valve Driver Circuit - Voltage Above Normal or Shorted to High Source. Open circuit or short to voltage source detected at fuel shutoff valve circuit.
I bypassed the fuel shut off valve made it to Peterbuilt will see what they say tomorrow
