Cylinder liners getting lobed and causing excess oil consumption as early as 35k miles of engine life...
https://quickserve.cummins.com/qs3/pubsy...40030.html
Quote:The date code is formatted as Day, Year, and Shift. For example, "138 2 3" would translate to the 138th day of the year, the year 2012, and the third shift of the day. This code would be May 18th, 2012, Third Shift.
Liners with an XPLZ marking that are produced after the date code 271 3 1 are not suspect for lobing.
Liners with an ABDJV marking are not suspect for lobing.
It looks like they changed the material/design of the liners to help prevent this after 9-28-2013, so if your engine was built before then, it likely has liners potentially prone to this.
Nice! This is my favorite thread!
Goes right along with Rawze's Failure Analysis
Engineering Research.
I second that Vin!! Rawze you should re-name this thread...."Fixes for Cummins current Blunders!"
