Could somebody let me know what part number they use for the brand new ISX heads? I the part number I came up with is showing only 1 in the country (Aus) and it's double the list price of a recon head.
Cheers.
When I called, they told me the part number was the same except at the end of it.....
RX for reman
NX for new
5 week build time as there were none available at the time.
It was the same when I did my in frame... It took a week or two to find one, I called all over and located one at a Cummins shop that someone ordered and never picked up. And yes on what Brock stated.
Strange-I have bought 3 of them and only take about 10 days-2 weeks to get. Also only 400$ difference from my dealer for Reman vs new.
I will be doing my inframe soon .As long as you have all your correct numbers off motor is there any reason I coud not order one in advance?Or for some reason do you need to have the old one off first?Rawze did you have any trouble getting a new head when you did yours?
Just called cummins tampa they shoe one in atlanta and said there are several around the country.4700.00 and change retail..signiture620 is in AUS...My guess that is the issue
4331387 $3537.43 plus state tax.
Thats a big difference from what tampa cummins told me
$4700.00 and change is probably retail, we don't pay retail, the PN that I gave has been superseded to PN 5413782, there is one sitting at the KW dealer in Laredo for $3551.25 + tax, I can PM you the salesman number if you are interested in buying it.
*this is for a CM871
