I did it. It works. It was well worth the time.
attachment=2841]
The mount uses the factory cab shock points and is nice and secure
attachment=2842]
I just have a simple mount for a generator for now.
attachment=2843]
And while I was at it i removed the heavy exhaust and turned it into a weed burner style.
attachment=2844]
We have a good customer that has this unit but with a honda genset. He said it works great and has had it for 2 years now..
I've only seen the one Snailexpress posted. It works awesome.
A guy had a generator on his truck. Real nice set-up. But the fuel tank on the generator was removed. He had a split fuel tank for the truck. The side which would have had hydraulic oil had gas, and a 1 psi pump to supply the generator. Reason being, he said gravity fed gasoline systems were illegal on a truck.
Do you know anything about that?
(06-16-2017 )Mrkentee Wrote: [ -> ]A guy had a generator on his truck. Real nice set-up. But the fuel tank on the generator was removed. He had a split fuel tank for the truck. The side which would have had hydraulic oil had gas, and a 1 psi pump to supply the generator. Reason being, he said gravity fed gasoline systems were illegal on a truck.
It's OK to use generator fuel tank.
But something like [
attachment=2850] is no-no
393.65 subsection d states
(d)Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector.
