02-19-2016,
02-19-2016,
Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly?
02-19-2016,
(02-19-2016 )Grape Ape Wrote: [ -> ]Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly?
It has never worked since I had it. Cruise works fine. I guess it is disabled. I meant to mention it to Rawze when he did some work on it but forgot. I will check out when I get home. Thanks
02-19-2016,
(02-19-2016 )axe Wrote: [ -> ](02-19-2016 )Grape Ape Wrote: [ -> ]Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly?
I would be happy to turn it on for you next time you get a chance to stop by this way. it is just a setting in Insite.
02-19-2016,
(02-19-2016 )Rawze Wrote: [ -> ](02-19-2016 )axe Wrote: [ -> ](02-19-2016 )Grape Ape Wrote: [ -> ]Could you ever do it, or is it recent? If you never could, it might just not be enabled. You can set that parameter with Insite. If it's a new issue, does the cruise work correctly?
Thanks Rawze. See ya soon
02-19-2016,
which setting? one of my trucks does it with cruse and the other doesn't.
do you remember which one it was?
02-19-2016,
(02-19-2016 )Crafter Wrote: [ -> ]which setting? one of my trucks does it with cruse and the other doesn't.
Here is what mine looks like
[attachment=1115]
and here, though i think this is different for different model trucks.
[attachment=1116]
