09-07-2017,
The power divider is leaking out of the seal. Has anyone replaced the seal? How difficult is it? Any special tools needed? It's on a Volvo if that matters.
(09-07-2017 )Mr Hagg Wrote: [ -> ]It is just silicone. Just slide it forward and clean it good and reseal it. The biggest issue is the internals. You have to pay close attention to the gears and lever in between they will try to fall out.
(09-07-2017 )Tcarpenter Wrote: [ -> ]The power divider is leaking out of the seal. Has anyone replaced the seal? How difficult is it? Any special tools needed? It's on a Volvo if that matters.
(09-07-2017 )Rawze Wrote: [ -> ](09-07-2017 )Tcarpenter Wrote: [ -> ]The power divider is leaking out of the seal. Has anyone replaced the seal? How difficult is it? Any special tools needed? It's on a Volvo if that matters.
Question is WHY is it leaking?
* breather tubes get clogged up?
* Did it get overheated?
* Is the gears worn slap out and causing problems?
* Road debris hit it hard?
* It get twisted from running into the ditch?
* Is the silicone seal rotting out because of age? -- maybe it is a sign that it is time for new rears before it puts you on the side of the road?
