Does anyone know of any youtube vids on replacing rods & main bearings? Sequence? One at a time etc? Torques? Thanks
You can find everything you need to know, at quickserve.cummins.com
Btw, have you found problem on your engine, popping noise?
I haven't hhow55, looked at a couple things but everything looks ok, haven't had much work which is perfect time to check these things but weather hasn't cooperated much Saturday is supposed to be nice. Thank you.
Do you have a set of timing wedge's, or access to set?.
I would check the base timing
I don't, I was looking at that a set on ebay, have the injector leak test tool comming
Thank you Sergiu! Sorry hadn't looked at this all day
