12-21-2017,
12-21-2017,
putting in a long block then old block goes to cummins for inspection, core charge is $11,000 so fingers crossed.
12-21-2017,
liner can't drop that far unless step broke. Sounds suspicious.
I would have gone with a short block and pulled the liners out of it, shimmed them to 0.014", then put on a new head if it were mine. Guess i am just stubborn to trust a factory reman engine these days.
12-21-2017,
got to see a little of it today. block just off the ground. took some pics sticking phone under only one came out good but good enough to see what looks like liner busted through bottom of what looks like four thumb size tabs that bottom of liner sit on. (if that's right). there saying its not a recon,and that its a new engine no rx number. rating plate very small and most every stamp is NA (horsepower) ect. would upload pic i have, but dont know how.
12-21-2017,
Sounds like you may have lost a piston cooling nozzle thus cause for low oil pressure to begin with. THen the piston seized to liner...
12-21-2017,
any way i can post the one picture i have or pm me and i can email it to you?
12-22-2017,
(12-21-2017 )Mr Hagg Wrote: [ -> ]Sounds like you may have lost a piston cooling nozzle thus cause for low oil pressure to begin with. THen the piston seized to liner...
Ouch, never thought a siezed piston would pull the liner through the shelf...wow!
12-23-2017,
While I'm sorry at your misfortune and don't wish it on anybody, if that is true and it seized like that...that's impressive, for lack of better words.
I figured it would have a piston skirt clearance that would have kept that from happening? I figured a burnt piston and a scored/damaged liner if it lost a nozzle...
Scary to think that could happen that quickly.
12-23-2017,
