it stops nothing with the fuel pumps exploding. all it does is when the filter plugs off when the pump explodes oil pressure drops long enough before it bypass to shutdown/give you some warning of shits going bad. cummins bandaid on a amputation!
(05-27-2017 )Unilevers Wrote: [ -> ]it stops nothing with the fuel pumps exploding. all it does is when the filter plugs off when the pump explodes oil pressure drops long enough before it bypass to shutdown/give you some warning of shits going bad. cummins bandaid on a amputation!
:(:(:exclamation::exclamation::exclamation::exclamation::exclamation::anger:
