04-29-2018,
Guys who run with low fuel tanks all the time end up with algea issues a lot too. Every time your windshield fogs up because of sudden temp changes, so does the insides of mostly empty fuel tanks.
(04-29-2018 )Chamberpains Wrote: [ -> ](04-28-2018 )Evotrucker Wrote: [ -> ]Okay so when you drain the tanks what do you clean them with? I'm still thinking of ways to cleaning it properly. I've got a idea to disconnect the fuel lines, drain the tanks, fill them with water, get a cement mixer, hook it up with a drill and do that couple of times. Till it's clean enough. Sound like a good idea to you?
Why in the world would you introduce water into your fuel system at any time? Water is your enemy!! The algae live in water and feed on fuel. If you get the test back positive for algae then drain the tanks as best you can. I usually take them off or park the truck on a hill close to the aluminum welder and drill a hole in the bottom corner of the tank and get every drop out I can and let it dry if possible to kill as much as I can. Weld the hole back up and then have a pile of filters on hand. Throw a quarter tank of fuel in at 1st and give it a strong treatment of algaecide and run the truck cycling thru filters as necessary till no more algae is present. Testing to confirm.
Your filter looks like asphaltene. Dont get excited unless you're getting very rapid filter plugging.
