05-22-2018,
No, just damned. Get a new head. Sell your couch and tv if you have to. Like Smokey the Bear says, don’t play with fire. Welcome to ownership.
(05-22-2018 )Evotrucker Wrote: [ -> ]so today after i picked up the head from the shop, they told me that i had 3 injector cups go bad and that are leaking... great. okay, so the shop has a isx head thats remanded at the shop for 3.5k, sound reasonable? or my other option is the send the head back so they can send it somewhere else to replace all of the injector cups for $900.You have to try yourself as treasure hunter. They are so stubborn to dig or dive or climb no matter what the expenses and outcome will be. Disregard thousands people experience who did it before you and fail.
also to note, the shop charges 1.5k to clean and rebuild the head, if i have to. the head was rebuilt in the last over haul, so i'm not sure if the head needs to be rebuilt all over again.
(05-23-2018 )Evotrucker Wrote: [ -> ]tuesday is when the parts are coming in, getting 6 brand new injectors. sending the head out to fix the injector cups and hopefully ill be able to get back to work next monday.
this is by no means what the standard is on this forum, tho if i had the financial means to do it right it would be a different story. ill let you guys know next week how its going.
take care guys!
(05-03-2018 )Rawze Wrote: [ -> ]A screeching turbo sound can also simply be a turbo mounting gasket too. have seen that a lot more often that the turbine giving way. If you suspect the turbine, then you will see metal shavings and a chewed up turbine.Finished an egr tuneup. Put everything back together and went for a drive. Terrible screech when exhaust pressure got above 60in hg. Louder on driver side than area around the turbo. Gasket between egr valve and pipe had shifted during assembly. Glad I searched the archives before tearing things apart. Thanks!
(05-23-2018 )Chamberpains Wrote: [ -> ]What did you decide on for a repair on the bottom end?
