I'm looking to change the def filter on my 2011 kw t660. Can anyone tell me where in the def tank it's located? I looked under the tank but I don't see anywhere the filter might go.
(04-14-2016 )jimeneztrans84 Wrote: [ -> ]I'm looking to change the def filter on my 2011 kw t660. Can anyone tell me where in the def tank it's located? I looked under the tank but I don't see anywhere the filter might go.
its in the bottom of the dosing pump. go directly underneath it (on the backside of the DEF tank) and take the 3 bolts out to take the metal shield off. then there will be a round bulb that has a 1 1/8 hex head on it. spin it off and pull out the filter. resemble in opposite order.
(04-14-2016 )Unilevers Wrote: [ -> ] (04-14-2016 )jimeneztrans84 Wrote: [ -> ]I'm looking to change the def filter on my 2011 kw t660. Can anyone tell me where in the def tank it's located? I looked under the tank but I don't see anywhere the filter might go.
its in the bottom of the dosing pump. go directly underneath it (on the backside of the DEF tank) and take the 3 bolts out to take the metal shield off. then there will be a round bulb that has a 1 1/28 hex head on it. spin it off and pull out the filter. resemble in opposite order.
It to dark to take picture some DEF units filter cap is ribbed like top plug DAVCO water separator.
Thanks unilevers!! Ur the man!!
