So I’ve watched the EGR tuneup video. Just have a quick question. It didn’t show you cleaning the pipes and such. Do you use the carb/choke cleaner and like a wire brush or something to clean them?
Yes, you need to clean the piping. I used Palmolive dishwashing liquid, the green colored. I picked up a toilet bowl brush, and it all came clean.
(07-22-2018 )hhow55 Wrote: [ -> ]Yes, you need to clean the piping. I used Palmolive dishwashing liquid, the green colored. I picked up a toilet bowl brush, and it all came clean.
Ok I wasn’t sure if I should use any cleaner. I was just reading Rawze’s article about it and he said using cleaner can cause it to collect soot even faster afterwards. Maybe it depends on what you use.
