going to replace engine fan today, anything i should now about looks simple enough. do i need to locktite the bolts?
Just the fan blade? If you can, loosen radiator stays and shrouds to help with access. Pretty straight forward otherwise.
okay thats what i did also had to remove intake pipe from cac to that pipe that says hot. was pretty simple once shroud was off. one new bolt was missing from top of shroud wonder if that hit fan blade and broke it small chunk was missing but no cracks.
thanks signature620
