Hey everyone! Does anybody know the flash codes? I have a check engine light and a flash code of 3545. Any help would be greatly appreciated.
Looks like a code for a bad nox sensor on the outlet side of the aftertreatment. It has a abnormal update rate. Could be as simple as a blown fuse or as much as a bad sensor. They arent axactly cheap if thats what you'll find to be bad. Set yourself up a free quickserve.com acct, you should have that anyway.
