Trying to figure out why I only see one v clap numbers 37 I need both ends any clue were I can find the other part number so I can order it..thank
The other clamp is on the oem side. It wont show on quickserve. Talk with your local dealer for that.
(09-12-2018 )Starlight Wrote: [ -> ]The other clamp is on the oem side. It wont show on quickserve. Talk with your local dealer for that.
Ok thanks .the dealer I been dealing with are not to bright but will try them again in see what's going on
