04-25-2016,
This Antique hydraulic pressure tester proves to be invaluable on a CM2250...
Someone was at Mr. Hags shop today with an engine "skip" that no one whatsoever could find. The engine would fail a rail pressure test and the pressure would fall from 28,000 PSI down to about 7000 is about 30 seconds, so there was definitely a leaky component, but there were no alarms, and all other means to find it including all cummins procedures and tests revealing no results, including cranking the engine and looking for bubbles coming back from on each injector (injector leak test).
Finally Mr. Hag got a little creative, and rigged up this antique machine to put pressure on each injector,.. and sure enough,.. When the pressure got to 4500 PSI on #6 injector, it revealeed that it would bleed. All the rest of the injectors passed.
This saved this guy a whole lot of money in guess work, as CM2250 injectors are more than $1200 each.
its typically called a "Diesel Injector Nozzle Tester" or a "Poppet Tester" ...
[attachment=1412]
(added 08-04-2019)...
here is the modern version. A person would likely have to make an adapter to fit the ISX.
(pic)...
[attachment=8321]
https://amzn.to/3165FZm
or...
https://amzn.to/3FRSXUw
[attachment=1412]
(pic)...
[attachment=8321]
or...
Tags:
poppet tester, injector testing injector test, CM2250 injectors, CM2250 injector test, CM2350 injector leak test, CM2350 injectors, cummins injector leak test, cummins injector leak, cummins fuel leak
