Hello everyone!
Getting ready to tacke this task thisweekend, does anyone know if I can find step by step
Instructions in the cummins book? Done them before on my Cats never in my Isx I hear the oil pump hast ti b shimmed like a pto...Thanks
It's in the service manual, click
1. Base Engine
2. Bearing Main, then scroll to the bottom of this page, look for install lubricating oil pump, and click on the link
voila!!!!
Then read and study all the step's!!!!
(04-26-2016 )hhow55 Wrote: [ -> ]It's in the service manual, click
1. Base Engine
voila!!!!
Mr.hhow 55!! Long time no speak!! You're using the words scroll & click lol cummins quickserve? Computers...Sigh lol Thanks buddy
(04-26-2016 )Coco620 Wrote: [ -> ] (04-26-2016 )hhow55 Wrote: [ -> ]It's in the service manual, click
1. Base Engine
voila!!!!
Don't forget LOCTITE and 6X6
Hhow55 your tip was very helpful found procedure for main bearings of course printed enough copies for an army ran the printer out of ink & paper got myself yelled at lol snailxpress I know this sounds dumb but what is 6x6? Thanks for your tip btw.
You will get to a point in the Oil Pump Installation where it asks you to find the Letter on the block
attachment=1422]
Lets zoom in on that
attachment=1423]
You will probably need a scraper to see it under the crud, look for it here
attachment=1424]
The 6x6 is to raise the truck one under each steer tire coco620
(04-27-2016 )gatow900 Wrote: [ -> ]The 6x6 is to raise the truck one under each steer tire coco620
Shoot .... I thought is 6 pack times 6 of your favorite one out off the fridge. Damn it .
