871 w/holset turbo leaking under clamp. I assume I'm going to r&r a gasket. Anything I should be aware of and any source for miscellaneous parts?
attachment=4466]
As far as I know there is no gasket there. That part of the turbo is being sealed with some type of glue, I heard someone calling it cement.
There os a brass or copper ring in there....make sure you mark the position of the housing so you can get ot clocked back in the right position.
Yes there is supposed to be a sealing ring there instead of a gasket.
