12-09-2018,
Have an issue with my 2350 it driving on the road to start brits a lot of white smoke in the in about 20 minutes later it says pull over and do a regen
(12-09-2018 )Nilao Wrote: [ -> ]You have DPF issues. Only time i have seen them smoke is if they have a crack.
(12-09-2018 )ETITRANSPORT Wrote: [ -> ]Have an issue with my 2350 it driving on the road to start brits a lot of white smoke in the in about 20 minutes later it says pull over and do a regen
(12-10-2018 )Rawze Wrote: [ -> ]We did the her tune up replaced the imap sensor replace the back pressure sensor on the filter replace the EGR differential pressure sensor cleaned out the tubes on the filter of pull down the filter looked at inspected it Did a force region on it everything went fine and temperatures and once again after about a 150 miles at basket for a regioe. again going down the road. Did injector performance test it passed fine did disown or cut out test it past find the air-to-air everything's no leaks really loss on how to fix his issue pain the butt pulled over every 160 miles next 45 minutes donor regen(12-09-2018 )ETITRANSPORT Wrote: [ -> ]Have an issue with my 2350 it driving on the road to start brits a lot of white smoke in the in about 20 minutes later it says pull over and do a regen
It is quite common for a truck that the DPF is not getting hot enough to white-smoke like hell as soon as it sees a hill. This is because the fuel did not ignite properly, built up in the DPF, then lit all at once.
engine and egr problems are always to blame. the emissions systems and its filters are just that,.. FILTERS, -- they don't clog and have problems unless the engine is spitting out soot, oil, coolant , etc. to cause those problems.
start by doing an EGR tune-up, replace sensors and clean out all the EGR piping and crossover tubes. - That should have been the FIRST THING done,.. not that thing that gets done after you waste thousands taking it to morons who are only there to steal your money and could could care less on actually solving any real problems.
