12-12-2018,
Looking for info on 2006 Oil Pan Gasket Replacement.
1. Is there a gasket upside (to the block) or downside (to the pan) I should be aware of?
2. Is there a particular bolt pattern to use?
( Circular, just doesn't sit well in thought.. Pan is to large... I think! )
3. Use Silicone? Top side ( Block ), Silicone ( Pan Side ) or both?
4. Recommended silicone for reused oil pan, if any?
5. How much silicone to use, if any? 1/16 bead outside perimeter.
All help provided will Truly be Greatly Appreciated...
Thank You,
R. Taylor
Thank You,
R. Taylor
