Rawze, your IR camera was very impressive, price was a little high for my budget. I found this little gizmo from FLIR and at $250 very affordable for anyone with a smart phone.
How does it compare as far as resolution?
http://www.flir.com/flirone/content/?id=69420#specs
(02-22-2016 )in2trux Wrote: [ -> ]Rawze, your IR camera was very impressive, price was a little high for my budget. I found this little gizmo from FLIR and at $250 very affordable for anyone with a smart phone.
The resolution is very very low, so they make up for it with a second camera.
I did a lot of research before I got the therm-app.
Here are some pics from different people's engines that come over here to get their truck straightened out, custom tuned, etc. -- I don't mess around.
attachment=1132]
and some battery problem..
attachment=1133]
and hot-spot in ECM ...
attachment=1134]
Thats what struck me about your camera, the high resolution. Very cool!
What a great tool! No way you would spot those problems otherwise.
Makes a temp gun look like a toy!
All this talk of thermal imaging, I'm surprised nobodies mentioned cats new toy the S60 a mobile cell phone with the thermal camera built right in running on Android, it boasts some pretty cool features. Here's the like to read up on it.
http://www.cnet.com/products/cat-s60/
If it worked on goolge fi ID get it for bragging rights an the rugged tough build, cause I'm forever dropping my phone.
[/quote]and hot-spot in ECM ...[/quote]
Does a hot spot on the ECM indicate a problem? If so, what temp or above constitutes a hot spot with engine at normal operating temp?
(03-05-2016 )texasmorrell Wrote: [ -> ]Does a hot spot on the ECM indicate a problem? If so, what temp or above constitutes a hot spot with engine at normal operating temp?
That particular ECM was still working. It just was a little hotter than I see them get on the inside, indicting it was likely weakened at some point by a bad sensor or actuator
