I have a 14 liter Detroit pushing water out of the radiator tank can someone tell me the issue it has been modified
Blown head gasket? And by modified, deleted? If so, when and by who? What year truck/motor/brand... Do you have pyro and turbo boost gauges? Any over heating or codes? Need more info.
You can get a block tester with the correct fluid from Napa to check the head gasket.
(08-29-2019 )Speedy Wrote: [ -> ]I have a 14 liter Detroit pushing water out of the radiator tank can someone tell me the issue it has been modified
blown head gasket is the most common scenario when you have a typical hack-job, take-your-money-and run delete.
Get with Unilevers, or mommaburt (possibly gearhead) to have the program straightened out if one of those guys was not the one who did it.
