11-16-2019,
11-16-2019,
Who did the delete?
11-16-2019,
I did the hardware work and i got the file from some one the forlum
11-16-2019,
(11-16-2019 )vcshop Wrote: [ -> ]On a cm2250 delete file can a person pull the file out and use it on an other cm2250?
Assuming the CPL's, truck make.model, etc. match exactly...
Everything from injector trim codes to all settings, features and params like vin#, all collected data like cylinder balance data etc. wrong, correct miles, trip info, etc.
If the CPL's do not match, or truck don't match exactly, it can be much much worse like rear ratio, fan clutch type/settings, tranny type and settings, truck intake and exhaust piping and sizes, tire size, rear ratio, internal engine component settings, possibly injector offsets , etc. is mostly going to be wrong too.
So the answer is basically... a strong NO. NOT recommended at all, even if the engines and hevicle are identical.
