A friend of mine was in Chicago today and all of a sudden his engine decides to surge and run rough. As I was on the phone with him I asked him to start the truck since the check engine light would not light up to show a code. It would not start. One of his tanks was empty and the other full.
Because the check engine light went out I considered the possibility of a fuel line clogged or a junction valve not working right. He did get fault codes off his Rawze approved ....lol.... Keven Ruthurford scangauge but the codes dont make any sense. Here is the video so lets start with that.
My call is fuel starvation caused by a problem in the fuel system before the fuel pump.
https://www.facebook.com/broughamls/vide...914572964/
What kind of truck is this?
One tank empty, the other full? Maybe he sucked up a bunch of air and lost the prime.
Is it an international? Bad transfer pump maybe. I'd get some fuel in that tank a fill the filter up and see if he can restart it.
(06-27-2016 )preacherboy24 Wrote: [ -> ]A friend of mine was in Chicago today and all of a sudden his engine decides to surge and run rough. As I was on the phone with him I asked him to start the truck since the check engine light would not light up to show a code. It would not start. One of his tanks was empty and the other full.
It will run rough like that for up to 10 minutes after air has gotten into the fuel system.
I don't like the scamgauge so much,... I think the roadrelay is better instead.
https://cumminsengines.com/roadrelay
the full tank has something obstructing the fuel suction tube, it is probably getting fuel through the return line and overflowing through the breather tube, the empty tank is thus running dry.
(06-27-2016 )Rawze Wrote: [ -> ] (06-27-2016 )preacherboy24 Wrote: [ -> ]A friend of mine was in Chicago today and all of a sudden his engine decides to surge and run rough. As I was on the phone with him I asked him to start the truck since the check engine light would not light up to show a code. It would not start. One of his tanks was empty and the other full.
I want one of these Roadrelay units! There are two, a 4 and 5 version. The 5 version has a hookup for the Inline/Insite reader. So, will the 5 version work with my un-mandated CM871? Any idea on cost? Seeing used #4 units on fleabay for $200 and up. Thanks Rawze for the info!
When mine did this, it was the block valve on the return fuel line that was bad.
Guessing the fault codes were fuel pressure related.... They blew air back to the tank and whatever was blocking the line went back to the tank. Truck runs fine now. I told him he needed to run the tanks down to 1/4 and put a borescope in to find what blocked the line.....and remove it.
