(12-04-2021 )tree98 Wrote: [ -> ] (12-03-2021 )BLAKE7700 Wrote: [ -> ]I was told more than once there shouldn't be anything wrong with the ecm file through efi
And we told you from the start that it WAS a problem lol, I'm glad you got it fixed.
Yeah I know haha, but I was told to keep looking for another problem. So I did. I really appreciate all the help from yall.
I know this is a old thread but anyone have any idea who helped this guy on Insite with this truck I’m having the same issue
Have you read this entire thread and followed all the advice?
Yes been diagnosing on truck for a couple days. Have 60 ohms on can
Have checked wires from ecm to vgt
Have check voltage and ground at vgt and have battery voltage
I start truck runs fine with no codes for about 20 seconds then 2636 comes up and vanes default to 0%
(08-11-2022 )Fowjacob Wrote: [ -> ]I start truck runs fine with no codes for about 20 seconds then 2636 comes up and vanes default to 0%
what make/model truck?. what engine ser#?.
Is it de-mandate?.. and if so, you need to have the program reviewed for correctness.
