03-08-2020,
Recently bought 36" Sleeper and installed. I am attempting to hook up the power to the load center.
I have the wire that plugs in under the sleeper to the Sleeper Load Center.
1) I assume one end goes to the battery box. Is this a ground or a hot to the battery box..
2) The other end I assume goes to the fuse box... Where does it connect into the fuse box.
3) Does the wire run the frame to to fire wall and then into the fuse box? Or does it run up through sleep and thru cab into back of fuse panel?
4) How does this thing route?
Any help will be greatly appreciated
