Did a oil sample at speedco the numbers I see look very different from before. Please let me know if there way of or are they good thanks [/php]
Looks ok. Sodium is up a little. Watch for coolant loss.
I guess you're doing extended changes.
Personally, I don't have much faith in Speedco oil analysis. I'd rather send it to a lab.
The highlighted viscosity number is only one point above spec, and two points higher than two samples ago. Doesn't seem like much.
I went the extended drain route with my last truck with a Cat, with a big bypass filter.
Now I have the Amsoil bypass filter but I'm still going to change at 15,000.
The rebuild only has 45,000 on it. The samples are coming back excellent. The lab is recommending extending drains. I might go 20 but that's about it.
(07-07-2016 )Mrkentee Wrote: [ -> ]Looks ok. Sodium is up a little. Watch for coolant loss.
thanks you for looking at it. the sodium is what's got me worry but I'm not losing any coolant. what lab would u recommend to send the oil to get check
There are several. I use Blackstone, but they charge extra for TBN and soot. So I don't get them. I probably should find another one. Maybe make a separate post about that, unless using names violates the forum policy.
I use polaris labs their do more precise analysis than speedco. Speedco shows like basic sample only metal wear, doesnt show how much additives like zinc, phosporus.
i get my oil sample test kits from Amsoil. i just sent in my 1st sample to them. we'll see how it goes.
