07-12-2016,
Pages: 1 2
07-12-2016,
Mine was an orange/reddish color silicon hose with a wire around it. I had that replaced when we did the in frame, much easier to get to with the head off... I guess it looks kind of like a bellow? Here is a link to one, and it is a good price to boot! Cummins is like $300+ for one of these damn things.
Cummins 3684238 Connection Exhaust Outlet Hose
07-13-2016,
(07-12-2016 )Nilao Wrote: [ -> ]A leaking bellows tube won't cause loss of boost. Will cause a lot of smoke under the cab during a regen. If you look under the passenger floorboard area you will find a braided wire mesh that covers the bellows area. It's main purpose is to allow the engine to move independent of the exhaust pipe. If it has a hole in it I would also expect to see failed regens.Thanks for the info. I'm guessing International is blowing smoke up my ass. I really appreciate the comeback.
PS Mine was leaking in 2 places and would only smoke during a parked regen. I had no loss of boost pressure as the bellows is after the turbo and all the exhaust has already past the turbo vanes.
Added picture of the bellows pipe.
07-14-2016,
(07-13-2016 )fatzlargecar Wrote: [ -> ](07-12-2016 )Nilao Wrote: [ -> ]A leaking bellows tube won't cause loss of boost. Will cause a lot of smoke under the cab during a regen. If you look under the passenger floorboard area you will find a braided wire mesh that covers the bellows area. It's main purpose is to allow the engine to move independent of the exhaust pipe. If it has a hole in it I would also expect to see failed regens.Thanks for the info. I'm guessing International is blowing smoke up my ass. I really appreciate the comeback.
If they're talking about the egr crossover having a hole innit then that could cause a loss of boost. Not a complete loss I wouldn't think. I would think you find it easy yourself as it should be fairly loud from the hole.
07-14-2016,
When you rebuilt, Did you replace injectors? ??
I rebuilt my c15 and they said injectors were fine. Truck always had low boost but finally I decided to swap them out because they had a million miles and my boost went way up, power through the roof and it was great on fuel.
Pages: 1 2
