06-03-2020,
Hello all,
The check engine light recently came on
. My engine isx15 2350 had dumped a lot of oil all at once. There was no signs of visible leaking. I opened the crankcase filter and had oil all in the filter. I removed the filter and hooked up Cummins insite. Fault 1942 crankcase pressure sensor erratic. The dumping of oil only happened once I noticed the turbo sounding a bit off, only while idling.
There's no coolant leaking , no oil leaking, however, I have noticed a significant decrease in fuel economy.
Check light cleared and 3 days later it emerged again.
Any one have a clue as to what's going on?
