I am due for a radiator drain and refill. I was curious about the best radiator flush product available today. Any suggestions?
Most radiator flush products are acid or alkaline-based. I would recommend avoiding them unless you think there's some serious scale build up or you've had contamination like oil/fuel in your coolant.
i have used a couple different ones. - I have had best luck so far with cummins restore.
(07-19-2020 )Signature620 Wrote: [ -> ]Most radiator flush products are acid or alkaline-based. I would recommend avoiding them unless you think there's some serious scale build up or you've had contamination like oil/fuel in your coolant.
Copy that. Thank you for your reply.
(07-19-2020 )Rawze Wrote: [ -> ]i have used a couple different ones. - I have had best luck so far with cummins restore.
Copy the "Cummins Restore" product. I will give it a try. Appreciate the reply Rawze.
On old farm equipment with lots of scale buildup .
What would you guys think of using crl .
