08-04-2020,
hello ,
I gave 2013 freightliner cascadia isx 15 .today i notice that i have a bad coolant leak under radiator its dripping like crazy. When i touched i noticed it s mixed with oil.
I check engine oil no water in it, i check coolant reservoir no oil in it, yesterday i had ultimate PM at TA shop, i don't know if the guy did some thing funny specially when he was trying to open the bolt down the pan he was tighten it instead of loosing it hopefully he didn't hit the bottom of radiator, i am not sure i don't want to blame him, also when checking the oil i find it overfilled way above the limits.
Any idea what can cause the oil and coolant mixed dripping bottom of radiator. Couldn't locate from where exactly it leaks thx so much
