Hi I've got an turbo boost gauge on order from kenworth for a t600. Wondering if anyone has experience installing a stock kw gauge to tie it into the existing boost sensor? I've wanted one to see the turbo psi what the computer is seeing. Kw has said it might need to be programmed in but I'm thinking it can be done with insite?
If it is a late model kw you can go in on ESA and turn it on and then plug and play. You will need the jumper wire too.
(07-21-2016 )Bahdan Wrote: [ -> ]Hi I've got an turbo boost gauge on order from kenworth for a t600. Wondering if anyone has experience installing a stock kw gauge to tie it into the existing boost sensor? I've wanted one to see the turbo psi what the computer is seeing. Kw has said it might need to be programmed in but I'm thinking it can be done with insite?
You will need to activate it with Paccar ESA software to get it working. -- don't know if you have read others threads about the factory boost gauges, but they are slow to respond (like 3 seconds or more lag/delay all the time) compared to a glow-shift or other brand of actual external boost gauges. I don't like the factory boost gauge at all.
Glow shift boost gauge was about a third of the cost of the international OEM gauge.
Oh boy, thanks for the info. They are about 94 each. But than kw needs to hook it up. My thinking was I could see the sensor that the ecm was looking at.
For me the issue is relying on a sensor that is known to plug up and read erroneously.
