I'm going to keep an eye on it.. when it starts getting worse I'll change it out. I just got done rolling new bearings and oil pump on Monday. Now I'm still fighting this fuel pressure rail code 1911, that hopefully I can fix monday and hoping it's not a fuel pump....
(07-23-2016 )jimeneztrans84 Wrote: [ -> ]I'm going to keep an eye on it.. when it starts getting worse I'll change it out. I just got done rolling new bearings and oil pump on Monday. Now I'm still fighting this fuel pressure rail code 1911, that hopefully I can fix monday and hoping it's not a fuel pump....
Can I ask where you had the bearings done?
Yes this shop in fontana, ca let me know if you need the info?
(07-24-2016 )jimeneztrans84 Wrote: [ -> ]Yes this shop in fontana, ca let me know if you need the info?
OK thanks, I had mine done last month at a shop in Indiana, Dumped out 8 gal of oil getting back to California, Replaced front crank seal and oil pan gasket
Oil pan gasket needs silicone on the corners where the block meets the front and rear housings.
All good now
