(01-02-2021 )ESDrepair Wrote: [ -> ]so i took out a 2012 isx esn: 79574017 3 plug ecm had a spun bearing
I was sent the program from this truck today (the 2250 engine that failed). Another bad delete.
the program is almost identical to this bad delete mentioned here...
http://rawze.com/forums/showthread.php?t...4#pid46124
(01-03-2021 )SquareOne Wrote: [ -> ]I can def attest to the procedure Rawze is referring. I currently have nearly 180k on the setup he tweaked in Feb/March of 2019. ----> 2250 modded ecm program running a 2350 engine. Very interesting the details that make those 2 engine types differ and like he mentioned before, most would never know as the 2250 ecm would initailly appear to run the 2350 with no issues.
Talked to them on the phone. Seem like some nice ppl.
They decided to put the 2250 ecm and wiring harness back on the truck, start over with it, and have that original 2250 ecm and wiring harness run the 2350 long-block and hardware.
I had them flash the old ecm back to stock programming (it had a bad delete in it /mentioned above ) and start over with a clean program.
They sent me the program out of the Cm2250 ecm. I edited all the settings inside it to run that 2350 block, cam, turbo, the 2350 injectors and trim codes, compression ratio, fuel-air-mix, intake & exhaust flow logic, etc.etc.etc. - all the engine-based settings according to the 2350's ser# and hardware. Hopefully this will fix them up, and hopefully there is nothing wrong with that used engine, as it has 250k miles on it or so and may have had a delete program in it as well?-- unsure what harm it may have had done to it by the last owner. maybe they will have good luck with it, at least the programming should now be ok for it.
(7 day follow-up) ...
Rawze is the man trust what he says he has a lot of knowledge did what he said to do with running the 2250 ecm on a 2350 motor and had Rawze sent me a program for it and it’s running amazing.
Thanks Rawze you the man bro !!!!!
(01-17-2021 )ESDrepair Wrote: [ -> ]Rawze is the man trust what he says he has a lot of knowledge did what he said to do with running the 2250 ecm on a 2350 motor and had Rawze sent me a program for it and it’s running amazing.
There have been several others on here that ended up in this same situation with no solution in the past. I just try to help others as best I can, noting more.
Thanks for the follow up .. had been curious how it all turned out for ya, as I had not heard anything back.
(01-10-2021 )Rawze Wrote: [ -> ] (01-02-2021 )ESDrepair Wrote: [ -> ]so i took out a 2012 isx esn: 79574017 3 plug ecm had a spun bearing
I'm in the same situation taking out a CM2250 CPL 3606 S/N 79552129 550HP(threw rod through side of block) putting in a CM2350 CPL 3938 S/N 79783431 485HP 239,000 miles on it, updating lower end with liners and pistons to the carbon rings. Would like to get the CM2250 ECM to work with engine to keep 550HP. What steps do I need to do, the mechanic has Insite....Thanks, Hillbilly
(02-26-2021 )HillbillyISX Wrote: [ -> ] (01-10-2021 )Rawze Wrote: [ -> ] (01-02-2021 )ESDrepair Wrote: [ -> ]so i took out a 2012 isx esn: 79574017 3 plug ecm had a spun bearing
Basically just have to have a copy of the program out of the 2250, pulled out via CT software and the ser# of the new enigne.
I will PM you my number.
I have a question for all that are in this thread I know it’s about 5 months old now but I am new to the forums. I have a 2012 isx cm2250 motor with a cm 2350 ECM my question is what needs to be changed so that it communicate together esn 79597170 cpl 3719 and the ECM cpl is 3937 and it’s a 2014
Thanks for your help and guidance
Diver
(11-10-2021 )Diver Wrote: [ -> ]I have a question for all that are in this thread I know it’s about 5 months old now but I am new to the forums. I have a 2012 isx cm2250 motor with a cm 2350 ECM my question is what needs to be changed so that it communicate together esn 79597170 cpl 3719 and the ECM cpl is 3937 and it’s a 2014
Diver
what truck is this on?... and what was the original engine ?... and what was the ser# of the original engine???
and I assume the the new enigne ser# is 79597170?
