02-11-2021,
What about DEF tank heater, DEF injector cooling?
First one will be coolant in DEF tank and the second will expel coolant into exhaust.
(02-11-2021 )Soulreaver0102 Wrote: [ -> ]Off the cooling system
(02-11-2021 )Waterloo Wrote: [ -> ](02-11-2021 )Soulreaver0102 Wrote: [ -> ]Off the cooling system
If there is no sign of coolant in the tranny, check that lower coolant hose and clamp... Serious, mine was leaking gallons too going down the road, and no sign of any leak... It was that winter when the temps were hitting 30 below... An old mechanic at the Petro caught it, after I had just spent four days and $3000 having a new EGR Cooler installed... This was before I found Rawze.com.
(02-11-2021 )snailexpress Wrote: [ -> ]What about DEF tank heater, DEF injector cooling?
(02-12-2021 )Soulreaver0102 Wrote: [ -> ](02-11-2021 )Waterloo Wrote: [ -> ](02-11-2021 )Soulreaver0102 Wrote: [ -> ]Off the cooling system
I will check it out. Did you do a pressure check and still didn’t see a leak?
(02-12-2021 )Waterloo Wrote: [ -> ](02-12-2021 )Soulreaver0102 Wrote: [ -> ](02-11-2021 )Waterloo Wrote: [ -> ](02-11-2021 )Soulreaver0102 Wrote: [ -> ]Off the cooling system
Yep, we let it sit overnight in a warm shop. It was the cold and heat mix of going down the road in that winter weather, it was pouring out of the lower hose when going down the road, and it left no trace. I put one of those high dollar aircraft Breeze clamps on and never had another issue.
Here is the clamp I use, Fleetpride does carry the Breeze brand, or you can get at Amazon. Just check sizing, they come in quite the variety. Love these clamps.
https://shop.azsupply.com/diameter-range...x-screw--1
Here is the manufacturer... http://www.breezehoseclamps.com/breeze/hi-torque/
(03-08-2021 )Waterloo Wrote: [ -> ]That old mechanic called it, what did I have to lose, a $10 clamp after spending $2500? It worked...
(02-12-2021 )Waterloo Wrote: [ -> ]Here is the clamp I use, Fleetpride does carry the Breeze brand, or you can get at Amazon. Just check sizing, they come in quite the variety. Love these clamps.
https://shop.azsupply.com/diameter-range...-hex-screw
