In which section do I find the part numbers for the IMAP, Delta P, and that other sensor for the EGR tune?
Click option view.
Some of the sensors will be under electronic control module, some will be under exhaust gas recirculation.
I found these part numbers searching the forums
4928594 pressure sensor
2897334 I map
4307166 delta
for 09 Cummins engine
I found the 4928594 pressure sensor searching though my engine. It’s in the exhaust gas recirculating section. Still searching to find the others before ordering parts.
