attachment=7736][
attachment=7736]My 2007 International 9200 just did this and never seen anything like this before. Truck appears to be running fine, tried shutting it off and cycling the key and cranked up but didn’t help. Added pic below. Thanks for any help.
What???? The speedometer needle??
Yes it quit working and threw a check engine lighting
Check your speedo sensor on the output shaft on the transmission. It's probably the wires, plug in to the sensor or the sensor itself are bad or broken or pinched.
Also, why is your voltage gauge above 14Volts. That seems a bit high if you ask me.
