Coolant sensor wire should have 5v, im getting 3.6v. Truck shows check emgine for low coolant.. Any ideas?
Did you ohm the sensor to see if it was within range?
Any body know of an issue with the coolant level sensor Freightliner uses causing issue or not working well with OAT coolants?
