06-01-2021,
Hello everyone. Before "the turbo situation" I was having an issue with my clutch (It is manual Eaton Fuller 10 speed trans) 820k on truck. It is being more than a few months since the clutch is acting weirdly once in a while. When I press it from a dead stop will not let me to engage any gear. So that makes me shut the engine off ( at traffic light for example) , put it into gear press the clutch and start the engine and this may not happen again for a week or two. I keep a close eye on the brake fluid and is always topped off.
When this happened for first time I open that small lid underneath and took a video which is not great and I am talking not in English there so I do not know may I share it here... Read the forum rules, but this all I got.
Anyways, I think it is time to replace the clutch and trying to find the right info for the procedure, as well as the tools and props needed. I know there are some other thing need to be looked at like gasket, flywheel surface, Rawze mentions in another post maybe the engine mounts need to be replaced while the transmission is off and so forth. Considering doing it myself since recently I got a good stretch of a smooth concrete.
Thank you all in advance for your suggestions.
