So, this truck has never had a sitting regen. Never. Until a couple of days ago. Driver said she got the message on the screen and had to stop and regen twice.
Does this mean the DPF is at the point where it needs to be cleaned? What if I went all milk money on it? And if I finally get off my dead a$$ and milk money this b!tch, won't the DPF eventually fill up with soot?
If it's needing parked regens, there is definitely something up with it. Might need cleaned or replaced, but there is most likely an underlying issue. Do you have insite? Done an EGR tune-up yet? I'd start there first.
I believe if you un-mandate it, you shouldn't need to worry. Might try and contact the fellas that have done it already. Should be able to get more info about it if you go that route.
I don't have the Insite yet. Probably gonna contact Hong Kong about that in the near future.
I have done the EGR tune up.
Upon the FIRST TIME that a truck turns on that light in the dash, asking for a "parked Regen",... you are already screwed!. The system is in DIRE MEED of some service work, EGR tune-up, etc. It is more like the idiot lights of the cars of the 1970's. By the time the light comes on, the damage is done and you are chasing your tail at that point.
These systems do not give early warning of impending problems,... they only complain AFTER THE SYSTEM IS IN DIRE STRAIGHTS!
(08-18-2016 )Rawze Wrote: [ -> ]Upon the FIRST TIME that a truck turns of that light in the dash, asking for a "parked Regen",... you are already screwed!. The system is in DIRE MEED of some service work, EGR tune-up, etc. It is more like the idiot lights of the cars of the 1970's. By the time the light comes on, the damage is done and you are chasing your tail at that point.
Thanks to you, I've already done the EGR tune up. Very shortly after that, I had to replace the EGR cooler. And now this is happening, but I'm only getting it "hear-say" from the driver who couldn't even tell me exactly what the message was. Just "something about truck will shut off." It's a Volvo, so it has the big(ger) screen in the gauge pod for messages and stuff. I haven't driven the truck myself in a few months, so I guess I'll head on over there and check Volvo's diagnostics screen. Maybe there's more information there.
My guess would be that you may have some DOC face plugging due to the EGR cooler failure, which would then really mess up any regen cycle that is trying to take place. Won't really know until you can get the codes but that would be my guess based on the need to replace the cooler. Was it a factory replacement cooler?
Crazy thing: That driver left me for another job, so I hired a new driver. Truck has not done it since. Although he does get anxious when the Volvo screen says that there's a regen in progress. I had to educate him on that.
So it had me thinking that even though I explained it to the previous driver, she just panicked and thought she was doing something when she parked it. Shucks, she didn't know anything about Volvo's display so I'm pretty certain she wouldn't be able to figure out how to force a regen. She probably just parked and turned up the idle and called it good.
She was having some personal problems at the time which may have clouded her reasoning.
Cooler was replaced at Cummins, so I'm thinking probably factory unit.
