(07-08-2021 )Cwmartinjr Wrote: [ -> ]I just had my engine Inframed . I ran the truck for approximately 250 and it's started to leak oil the it started losing oil pressure. When I 1st start the truck oil pressure is fine but within 10 miles it will drop slowly to 18 psi. At low idle oil pressure seems ok. To the truck back to the shop and they found they had installed the idler pull to the fuel pump wrong and it broke the bolts and sent debri into the oil pan but they claim the screen got it all. Would this affect the oil pressure and if not what could be the cause?
If that fuel pump (or other hardened component) failed and sent metal thru the engine ... your f$ucked without ...
A== Some kind of serious deep-cleaning flush with several hundreds of gallons of diesel-oil mix going thru the engine while it is run, using an external pump and filtration system.
B== The oil pump to be replaced. It will be pitted and damaged internally... and will eventually fail.
C== The oil cooler needs to be replaced. There is no way to get all of the metal shavings out of it thoroughly.
D== Pulling and inspecting a few (and not just one of each) of the rod and main bearings to see how extensive the damage is to the bottom end, wrist pins, etc... because it will be be inframe city if there is.
E== Inspecting all of the face gears and replacing all of them that may have gotten pitted.
F== All of the injectors and several fuel system components will also need replacing, as they will have metal shavings in them too, especially if the pump plungers are damaged. So... Injectors, high pressure relief valve, and the fuel rail + all fuel system components needs to also be removed and replaced and/or flushed too.
G== All of the top-end has to come apart and be inspected to see if there is too much s=damage. Also all of the rocker assemblies and rocker arms, etc. need flushing out, as they have tiny passages thru them for leak oil.. and shavings will get stuck in them, starving the overhead cam or cross-heads of oil.
- It is VERY VERY COSTLY ... a whole lot of flushing and work has to be done to it ... and time consuming to get the engine back into a reliable state and to stop all of the progressive damage after the fuel pump fails. This especially if some moron kept driving more than a few hours ... or worse, a few days or more with a bad fuel pump!.
Someone telling you that the "screen" caught it, is simply bulls$it, plain and simple.
In your case, it sounds like a warranty claim for a replacement engine to me.
