08-19-2016,
I was using the usb side and it doesnt work anymore.. Its broke. I want to use this side but I cant get it to work. Any ideas?
(08-20-2016 )Rawze Wrote: [ -> ]I used to use the Inline with Serial connections. it works, but is VERY VERY slow. Big risk in time-outs too, and not worth bricking someone's ECM.
It requires a USB to SERIAL adapter for most newer laptops -... or Wait!--- You said the USB is not working , Is it on the Laptop? or the Adapter USB?
If it is the Adapter USB,.. get another one -- It likely will have other failures to follow, and if it is on the Laptop,... well,.. you need USB either way!.
To make the Serial work on the Inline, You need a USB-to-SERIAL adapter, drivers for the adapter, and you need to re-assign all your engine software to use the COM port that you have assigned to the Serial adapter. You also need to set the serial adapter to com port 2 usually to prevent interference with other internal devices, such as your touchpad. Most touchpads are still PS2 driven, and usually take the the same IRQ as the old com 1 port did back in the day.
(08-20-2016 )preacherboy24 Wrote: [ -> ](08-20-2016 )Rawze Wrote: [ -> ]I used to use the Inline with Serial connections. it works, but is VERY VERY slow. Big risk in time-outs too, and not worth bricking someone's ECM.
The actual plug where the cord plugs into the Inline box is bad on the female side. I wanted to somehow install a more hearty plug like the serial but work with usb. On the inline 6 at the shop there is a bigger female plug that looks more hearty and tough. Just wanted to check my options because if I have to repair this female side I want to plug in the cord and glue it in! I want my Inline back!
(08-21-2016 )Rawze Wrote: [ -> ](08-20-2016 )preacherboy24 Wrote: [ -> ](08-20-2016 )Rawze Wrote: [ -> ]I used to use the Inline with Serial connections. it works, but is VERY VERY slow. Big risk in time-outs too, and not worth bricking someone's ECM.
this may help then ... https://amzn.com/B00EZK6I3O
Less than five bucks.
