I have a truck with cm870 all original set at 475.Truck started to surge under acceleration. It throws no codes however if you disconnect the egr it runs fine in a silent derate. Ran turbo egr test and all pass . Replaced fuel filters no change. Checked fins/actuator on tubo all good. Just put a new egr valve on it and same thing. Egr cooler not leaking....any other ideas?
do an EGR tune-up.. replacing the Delta-P sensor (and clean out the crossover tubes for it) + replace any other sensors that are old on the intake side of the engine.
also be sure to replace the exhaust back-pressure sensor and clean out its circuit thru the thermostat housing too.
(02-15-2022 )Rawze Wrote: [ -> ]do an EGR tune-up.. replacing the Delta-P sensor (and clean out the crossover tubes for it) + replace any other sensors that are old on the intake side of the engine.
Will do. Thanks
Great advice as always. Needing to do mine as preventative maintenance as well.
(02-16-2022 )Luckyjayb Wrote: [ -> ]Great advice as always. Needing to do mine as preventative maintenance as well.
it is a good place to start... but those CM870 can also start surging like that when the (air operated) turbo controller starts going bad too. - It is cheaper however to do a tune-up and cover the basics before starting to replace more expensive things is all.
I tore it apart yesterday and the one delta p line was plugged solid. Cleaned it all out and she's running like a champ. Appreciate the advice.
