My mechanic installed a new turbo actuator for me, as I was getting a spn 641 fmi 7. It ran great for 400 miles and now I'm getting an amber check light losing 25% power 1569 fmi 31. This is a 2013 cascadia 2250. Need a little help on what's causing this? Also this code 1569 came up before new install.
1569 fmi 31 is a derate code. Is the truck demandated? Do you have any diagnostics software? Feel free to pm me I can help you figure out your problems. Chances are your previous turbo issue caused more issues in your aftertreatment and the mechanic Didn’t catch them or slap ignored them….. but without connecting to your truck it’s gonna be hard to say.
Will have to read ecm to see whats going on.. THere should be more faults or you may have a bad delete
The truck is not deleted nor demanded. It used to be a Ryder truck
