10-08-2022,
10-08-2022,
rawze.com is NOT A SOFTWARE TRADING SITE!.
just an FYI: a 'BDG' meta-file has the same starting address and can be used to copying the file in/out of the ecm (backing it up, restoring it, etc. ) if necessary .. but not for documenting or editing it much. A 'BBN' metafile might also be able to be used for copying in/out of the ecm only too.
10-08-2022,
took a look at the BDP engine files. Looks like they use mode-6 (instead of mode-4) for no-egr operating mode. This is similar to other smaller engines like the ISB's. So anything CM2250 for the ISX is NOT going to be compatible to them.
If you have a vehicle that has been de-mandated, and you can copy the file out of the ecm, e-mail it to me, .. I can review it for ya tell you if the de-mandate is any good or not. The most likely scenario is some completely clueless fool trying to use/copy ISX settings on it.. and that would not be good at all.
