Hi everyone I have been getting code 2343 fuel filter differential pressure DATA VALOD BUT ABOVE NORMAL OPERATING RANGE LEAST SEVERE LEVEL. I have changed the fuel filter 3 times and the code keeps coming back. Has anyone experienced this code. I am trying to find it to solve the problem. I have ran fuel treatments 3times through the tanks . Is there a fuel pressure differential. New code new experience . Thanks Nate
Is it only the 2343? It’s not accompanied by a 559 is it?
What make/model truck?.. make/model engine?. - Maybe some history and if it is de-mandated or not?. Maybe an engine ser#?.
I have a 2015 kenworth t680 . It has Cummins isx 15 with 960000 miles . I have replaced fuel pump and tappets in 2022. This started after I put biodiesel in the truck. I ran 3 bottles of fuel injector cleaner thru it. Code keeps coming back.
(10-29-2023 )Bengy88 Wrote: [ -> ]Is it only the 2343? It’s not accompanied by a 559 is it?
[iyes be by it is has 559 inactive under it.[/i]
Engine serial number 79759039 Cummins isx 2350
Hey It happened again. I’m hoping someone can help me with this. Thanks
Ok rawze will do injector test when I get home to Md . Will let u know the results.
